Activity › Forums › Apple Final Cut Pro Legacy › Timecode doesn’t match up with subtitles
  • Timecode doesn’t match up with subtitles
    Posted by Cole Prine on October 14, 2008 at 1:44 pm
    So, I finally got the subtitles back for the latest video…when I try
    to import it into DVD Studio Pro, it would give me an error saying something
    about timecode not matching up or an incompatible format. So then, I
    realized that the timecode on the time code video I sent them starts with
    ’00’ and the actual timecode embeded in the video starts with ’01’. So I
    went through and changed them all to ’01’ and figured, ok I got it. Nope,
    I’ve just saw another little mistake…I use a time code generator to make the
    timecoded dvd – it runs 30 frames a sec. where as my video runs 24fps. So
    my timecode doesn’t match up. ARGH! So, does anyone have any ideas on how I can get the time code to actually match up? I guess I could dump it to tape.
    Oh, and I have a .txt and a .stl file of the subtitles.
    Cole Prine replied 17 years, 11 months ago 1 Member · 1 Reply
  • Cole Prine
    October 15, 2008 at 2:49 pm
    Hey everyone thanks for your help. I found two of the greatest tools to have when dealing with subtitles and they are free! Subtitle Xtractor and Subtitle TC-Converter. Both can be downloaded here: https://www.truevision-video.de/ With the Xtractor you can take subtitles from DVD STUDIO PRO, and convert them to a .stl. In DVD SP you just select the track that contains the subtitles, go to FILE>EXPORT>ITEM DESCRIPTION – this will give you a ,dspTrack file. You can then open this file using Xtractor and save it as a .stl, It also does some other stuff too.
    The TC-Converter will actually take subtitles that are timecoded at 30fps, and convert them to 24fps, and vice versa. It actually will convert from/to many different time bases. These are some great tools.
    Cole
