Activity Forums Apple Final Cut Pro Legacy Timecode Capture
  • Shane Ross
    February 13, 2006 at 4:41 am
    Via firewire. You can capture from the Varicam via firewire, and n that signal is timecode information.
    https://www.fletch.com/feArticles.asp?NextAction=Article&AID=216
    Shane
    Alokut Productions
    http://www.lfhd.net
  • Jeremy Garchow
    February 13, 2006 at 5:08 am
    Are you talking about on set? While shooting?
    I would look into a program called HDLog. It’s a logging program that you can use to log with timecode you have to buy an extra BNC to usb timecode reader. You take the tc out of the Varicam, and then you can log with HDLog. Then you can export out of HDLog through XML or text based “shot lists” to FCP. The trick is to find out if you can take that bnc to usb reader and plug it into FCP somehow. You’d need to find some sort of drivers for it but I’m sure it must come with some.
    Sorry if this info is vague, but it should lead you in the right direction.
    Read about HD Log and the timecode reader here:
    https://www.imagineproducts.com/hdlog.htm
    They have a free demo of the software.
    If you are talking about after the shoot, then the firewire workflow that Shane pointed out is tried and true.
    Jeremy
    G5 Dual 2Ghz <> 4GB RAM <> FCP 5.04 <> Kona 2
    ATTO 42XS <> Huge Systems 4105 Fibre
    OS 10.4.2 <> QT 7.0.3
  • Elliott Dunwody
    February 13, 2006 at 11:46 am
    Thanks, and yes it is for on set.
    Will check it out.
    Elliott
    Bright Blue Sky Productions
    4811 Rivoli Dr
    Macon, GA 31210
    http://www.brightbluesky.com
