Activity › Forums › Apple Final Cut Pro Legacy › Timecode Breaks where there are none
  • Timecode Breaks where there are none
    Posted by Bryan Fowler on August 17, 2005 at 1:17 pm
    I’ve been having problems during Capture with FCP stopping for Timecode breaks where the timecode was continous.
    FCP just slows down (like normal) and keeps on truckin. But the problem for us, it’s happening on almost every other clip. So to batch capture 5 minutes of video, it takes 10 or more. (every time it locates timecode, it’s 50-120seconds..or more)
    We are using Decklink Extreme, using SDI, and Digital Betacam.
    Computer is a Dual 2.7, with 4GB of ram, FCP 5
    Any known problems? I’m fairly sure we are all up to date with software and drivers.
    Bryan
    Tennessee
    Matthew Brunn replied 21 years, 1 month ago 2 Members · 1 Reply
  • Matthew Brunn
    August 18, 2005 at 2:29 am
    Have you had your DigiBeta unit serviced recently? Could be dirty heads. Then, is it happening with all tapes or just one. Could be bad tape stock. Testing to see which is the culprit is in order. Deck, cables or tape. Good luck.
    Hope this helps-
    Matthew
    Dual 500 G4
    OSX 10.3.5
    Ram 1.38
    FCP 4.5/AE 6.5/DVDSP3
