Activity Forums Apple Final Cut Pro Legacy Timecode breaks on dvcpro tapes
  • Timecode breaks on dvcpro tapes
    Posted by Dave Richmond on February 23, 2010 at 1:49 am
    Hello,
    We’re digitizing DVCpro 126L tapes with a Panasonic AJ-SD930 and keep getting TC breaks. FCP will continue digitizing 3 seconds later. There are no breaks and it stops at random durations.
    We are using DV settings through firewire.
    Has anyone else experienced similar problems?
    Dave
    daverichmond.com
    714 273 2534
    Dave Johnson replied 16 years, 7 months ago 3 Members · 2 Replies
  • Mark Suszko
    February 23, 2010 at 3:18 am
    Cleaned the deck’s heads lately? There should be a little LED indicator that indicates drop-out compensation is being applied. Does it flicker a lot?
  • Dave Johnson
    February 23, 2010 at 4:51 pm
    And, you’re not using re-used tapes are you? Personally, I’ve found all of the DV formats to handle re-used tapes poorly.
    Just to add my 2 cents to Mark’s good suggestion, you might consider having the heads cleaned professionally (versus using a head-cleaning tape).
