Activity › Forums › Adobe Premiere Pro › Timecode breaks on 1.8″ DVD from camcorder – common problem?
  • Timecode breaks on 1.8″ DVD from camcorder – common problem?
    Posted by Arjan on November 16, 2007 at 1:47 pm
    After getting no responses in the Canon forum I thought I might try here.
    I received some footage (part of a multi-camera and separate sound recording event) from a DVD camcorder , not sure what brand actually. Although the recording was continuous with no pauses or stops inbetween, StreamClip reports numerous timecode breaks when I used it to convert the 1.8″ DVD contents to a .DV file for editing in Premiere. Sure enough, I see and hear short interruption in the resulting .DV file (one continuous file). It seems as if the camera stopped recording for two frames and then resumed, resetting the timecode.
    Regardless of the timecode itself, the problem is that with each interruption (which like I said seems to last about two frames) the footage from this camera gets out of sync with the other two cameras, both of which were mini-DV cameras which stay in sync start to finish when aligned at the beginning.
    I’ve already started manually correcting the alignment after each break but my question is actually if this is a problem common to DVD based camcorders? I’ve never had anything like this with DV based cameras, just sync them up at the start in Premiere and they say in sync the entire length of the recording. Should I avoid DVD based cameras for multi-camera shoots? Heck, I’d like to avoid them anyway if only for their recording format but correcting these slips is time consuming and not something I’d want to do again.
    BTW I don’t have the camera itself nor have I tried putting the DVD in a DVD player and capturing it analog but since StreamClip is reporting timecode breaks I’m assuming that the problem is in the source DVD and not the conversion process.
    Arjan
    Arjan replied 18 years, 10 months ago 1 Member · 0 Replies
  • 0 Replies
