Activity Forums Apple Final Cut Pro Legacy Timecode breaks during capture. What’s the best way to deal with it?
  • Timecode breaks during capture. What’s the best way to deal with it?
    Posted by Jack Pitzer on November 29, 2006 at 2:26 pm
    Greetings,
    Every once in awhile while doing a capture, I get timecode breaks. I had the User prefs set to abort on dropped frames, and make new clip on time code breaks. I’ve turned both of those off and i’m going to try again.
    Is there a better way to deal with this? Is there anything I need to worry about once the capture is done?
    My capture deck is a Sony DSR-45.
    Thanks much!
    Jack
    Jerry Hofmann replied 19 years, 10 months ago 2 Members · 1 Reply
  • Jerry Hofmann
    November 29, 2006 at 2:33 pm
    If you have a ton of breaks, I’d dub the tape and create a new TC track. Use the dub as the source tape from then on…
    If you capture over a timecode break, the timecode recorded past the first break will be wrong, so recapture in the event you have to do this, would really involve a re edit…
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
