Activity › Forums › Apple Final Cut Pro Legacy › Timecode break problems with FCP and Decklink HD extreme
  • Timecode break problems with FCP and Decklink HD extreme
    Posted by Victor Kohler on April 1, 2008 at 7:53 am
    We are trying to capture Panasonic Varicam footage shot in 720p60 with a panasonic AJ HD1400 deck via my BlackMagic Decklink HD Extreme (im using Final Cut Pro 6.0.2 on a macpro latest version, leopard). Im capturing via a HD-SDI and controling the deck via the firewire. the problem is that Final Cut constantly detects timecode breaks in my footage and makes new clips which can be wherever in a take. So, a captured reel ends up as 5-10 clips instead of one file. I have tried to have the deck not hooked up via Frewire and controlling the deck locally itself, no difference. So the FireWire controller does not seem to be the issue.
    Otherwise the capture works fine. Is there a solution for this? I need to get this capture going during the day so please help!
    Victor Kohler replied 18 years, 6 months ago 2 Members · 2 Replies
  • Walter Biscardi
    April 1, 2008 at 11:47 am
    [victor kohler] “So the FireWire controller does not seem to be the issue.”
    Why are you controlling it Firewire and not RS-422? RS-422 will be a better way to control the deck.
    Walter Biscardi, Jr.
    Biscardi Creative Media
    HD and SD Production for Broadcast and Independent Productions.
    STOP STARING AND START GRADING WITH APPLE COLOR Apple Color Training DVD available now!
    Read my Blog!
    View Walter Biscardi's profile on LinkedIn
  • Victor Kohler
    April 1, 2008 at 1:10 pm
    ok! thanks!
    now capture is working. I just upgraded my drivers. It seems since i did not use the frame rate converter with the varicam and the drivers for my DeckLink were old FCP had problems with the signal or something.
    /victor
