Activity › Forums › Adobe After Effects Expressions › time value form another comp
  • time value form another comp
    Posted by Jaan Koppe on August 27, 2014 at 6:09 am
    Hi.
    I have a problem with an expression.
    I want to control a Glow value with a marker key from another Comp when a checkbox from main comp is checked.
    The nested comp starts from about 2 seconds.
    It work’s this way, but it start counting time when the nested comp (i.e. comp(“Box”) ) start’s in the Main comp.
    So when I place the marker on 2 seconds on the time line, then the Glow intensity start’s at 4 seconds.
    My code for the Glow intensity(this effect is in the nested comp):
    //Added the Math.round because it didn’t work otherwise.
    cb = comp("Main").layer("Adjustments").effect("Box Asset Glow")("Checkbox")
    m = Math.round(10*comp("Main").layer("Adjustments").marker.key("Glow On").time)/10
    t = Math.round(10*comp("Main").layer("Adjustments").time)/10
    if (cb == 1){
    if(t<=m){
    0
    }else{
    1
    }else{
    0
    Jaan Koppe replied 12 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
