Activity › Forums › Adobe After Effects › Time Stretching and Precomps
  • Time Stretching and Precomps
    Posted by Ryan Hill on August 14, 2012 at 11:26 pm
    I’ve had this crop up a couple times recently. I’ll have stabilized footage or an animated mask or something, and then I want to time-reverse or time-stretch or time-remap it. So I pre-comp it, moving all the animated masks and motion into the pre-comp, and then change the timing on the pre-comp.
    But then, the stabilized footage gets shaky again, or the animated mask doesn’t match up anymore. I guess what’s happening is it’s using the between-frame values for those animated elements.
    Is there any sort of setting I can change to make it treat the frames of the pre-comp as indivisible?
    Chris Nielsen replied 12 years, 6 months ago 2 Members · 2 Replies
  • Ryan Hill
    August 15, 2012 at 7:14 pm
    I was kind of hoping there was some sort of hidden check-box I could tick that said, “Treat this comp as though it were pre-rendered.”
    I’ll give the examples that inspired the question. I did resort to pre-rendering in these cases, but I was wondering if there was another way:
    Suppose I had a stop-motion sequence I wanted to composite into some video footage, and I spent a bunch of time masking out the feet for a clean key before realizing I had let it interpret the stop-motion as 30fps when the video is 24fps?
    Suppose I had a Super 8 transfer that was pretty shaky, so I stabilized it based on the sprocket hole, only to realize one piece of footage in the middle had been spliced in backwards, so it’s upside-down and time-reversed?
  • Chris Nielsen
    March 31, 2014 at 3:42 am
    I realize this is an old topic but I’ve recently had one of those…. hair pulling moments of frustration.
    Anyhow, my workflow always requires multiple levels of revisions, so prerenders don’t quite cut it for me. What I’ve found to solve this issue is rather simple – setting all keyframes to HOLD.
    Of course this could open a whole new can of worms for you depending on what exactly you’re stretching, but it’s always a handy trick for the back pocket. Thinking about what the software is doing – basically remapping the time between keyframes – it’s going to assume you want the tweens to operate in kind. Hold keyframes preempt this.
