Activity Forums Adobe After Effects Expressions Time Remapping – Unique Random playback
  • Time Remapping – Unique Random playback
    Posted by Tyler Jordan on May 4, 2012 at 4:32 am
    Hi there,
    I have a comp with time-remapping enabled, and a script to change the way the playhead scrubs, so that it will play one second from a random location in the comp and then move to another random location.
    What I would like to do is make it play the random location only once, so that I essentially have a movie clip the same length as the comp, and all of the content from that comp, expcept mixed up into a random order.
    Here is the random code I’m currently using as a starting point:
    segDur = 1;// duration of each "segment" of random time
    minVal = inPoint;
    maxVal = outPoint - segDur;
    seed = Math.floor(time/segDur);
    segStart = seed*segDur;
    seedRandom(seed,true);
    startVal = random(minVal,maxVal);
    endVal = startVal + segDur;
    linear(time,segStart,segStart + segDur, startVal, endVal);
    In other coding languages i’ve done similar things using an array and checking the scrubber against the times in the array, but i’m not sure how to do that in expressions, and also i think there is probably a more efficient way to do it.
    Any help is greatly appreiated, cheers!
    Tyler
    Tyler Jordan replied 14 years, 4 months ago 2 Members · 2 Replies
  • Dan Ebberts
    May 4, 2012 at 8:33 am
    This should let you divide the clip into n equal-length segments and play each segment once, in random order.
    n = 10; // divide clip into 10 segments
    segDur = (outPoint - inPoint)/n;
    segs = [];
    for (i = 0; i < n; i++) segs[i] = i;
    seedRandom(index,true);
    for (i = 0; i < n; i++){
    idx = i + Math.floor(random(segs.length - i));
    temp = segs[i];
    segs[i] = segs[idx];
    segs[idx] = temp;
    curSeg = Math.max(Math.min(Math.floor((time - inPoint)/segDur),n-1),0);
    t = (time - inPoint)%segDur;
    segs[curSeg]*segDur + t
    Dan
  • Tyler Jordan
    May 6, 2012 at 7:48 pm
    Thanks Dan, that worked perfectly.
    You probably recognised the original code, it’s from your motionscript site – lots of great resources on that site!
    Cheers,
    Tyler
