Activity Forums Adobe After Effects Expressions Time Remapped Layer Slider Control Expression
  • Time Remapped Layer Slider Control Expression
    Posted by Nimrod Zin on February 17, 2021 at 12:44 pm
    Hi…
    I have this expression on a layers opacity property. The Layer is time remapped so I could loop it in the original comp. When the Slider control is keyframes the expression doesn’t work.
    I get no Warning ⚠️ it just doesn’t do anything.
    I assume it has something to do with the fact it’s either time remapped or keyframes or both.
    Did anyone encounter this problem and found a solution? Maybe some kind of a value at time that I can’t figure out how to phrase?
    effectName=thisLayer.name;
    comp(“1”).layer(“1”).effect(effectName)(“Slider”)
    Thanks ?
    Nimrod Zin replied 5 years, 6 months ago 1 Member · 1 Reply
  • Nimrod Zin
    February 17, 2021 at 3:00 pm
    ok… figured it out.
    comp(“1”).layer(“1”).effect(effectName)(“Slider”).valueAtTime(time+PRECOMP_TIME_AT_COMP(“1”)
