Activity Forums Apple Final Cut Pro Legacy time remaping
  • Posted by Rui Carvalho on March 9, 2010 at 4:17 pm
    i have a problem whit Final Cut Pro 7.0.1 when i do my time remaping when i change fast speed to a slower speed, video seems to always jump in the transition. i have already used easy in and easy out but dont work, and stranger is that before render the video looks fine after render it begin to jumt e the transicion of speed. someone can help me?
    tanks
    PPX
    Rui Carvalho replied 16 years, 6 months ago 2 Members · 2 Replies
  • Jerry Hofmann
    March 10, 2010 at 2:06 pm
    Try setting up your speed change in FCP just as you have been, but then send the clip to Motion, Open the triangle next to the “retiming” parameter, and change the setting there to be “optical flow” from the pop up menu you’ll see there… save, and render in FCP.
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski.
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX Cinema Displays
  • Rui Carvalho
    March 10, 2010 at 5:23 pm
    tanks it works just fine
    PPX
