Activity › Forums › Adobe After Effects Expressions › time remap last key, after last frame for comps?
  • time remap last key, after last frame for comps?
    Posted by Andy Engelkemier on July 22, 2011 at 6:56 pm
    Why is it that when you add time-remap to the end of footage it adds the last frame to the last frame, but when you add time-remap to a composition it adds they last keyframe After the last frame?
    Is there a way to fix that other than going to the outpoint, adding a keyframe, then deleting the incorrect key after it?
    Is there a Good reason for this behavior? I Always have to change it. Why would you want the frame after that doesn’t exist?
    Andy Engelkemier replied 15 years, 2 months ago 2 Members · 2 Replies
  • Todd Kopriva
    July 24, 2011 at 8:02 pm
    This is one of those things that is “wrong” and annoying no matter which way we do it. If we put the last keyframe at the beginning of the last frame, then you can lose a frame of audio or truncate an animation by a frame—or even lose the last field of image information for interlaced material.
    We recognize that the dance of needing to move the last keyframe under some circumstances is annoying, and we’re currently working on a more elegant solution that solves this confusion without introducing the problems that we were trying to avoid when implementing it the original way.
    Technical Support for professional video software
    After Effects Help & Support
    Premiere Pro Help & Support
  • Andy Engelkemier
    July 25, 2011 at 11:59 am
    Ha, I didn’t think about audio. I suppose it would be helpful to not eliminate that last 1/nth of a second on that last frame.
    I had a script that sort of solved this before, but it was actually wrong. I just had it take the last keyframe and subtract one value. Of course, that adjusted the time slightly, so that’s no good.
    I wonder if you could put a preference? I think most 3d animators are going to want it one way, where most video compositors may want it another by default.
    Good to know that Adobe’s working on it though.
    I’d be happy with some sort of hotkey that just runs a script to do exactly what I’m doing now: Go to out frame, insert key, delete last key.
    That way it’d not ruin any data unless I specifically told it to. That might be a good solution until you guys figure out a more elegant one? And it’d also be backward compatible.
