Activity › Forums › Adobe Premiere Pro › Time remap keyframes move when using slip tool. Workaround??
  • Time remap keyframes move when using slip tool. Workaround??
    Posted by Frank Manno on March 14, 2009 at 2:46 pm
    I’m adding time remapping to a clip and need to use the slip tool to more accurately land the keyframes on sections of the clip.
    Problem is that the keyframes also ‘slip’ with the slip tool and end up elsewhere in the clip.
    Is there a workaround I can use to resolve this?
    Prem CS4
    -Frankie
    Kevin Sebastianpillai replied 16 years, 11 months ago 2 Members · 1 Reply
  • Kevin Sebastianpillai
    November 4, 2009 at 1:05 pm
    Sorry Frank, I don’t have the answer but have the same issue too…very annoying, it also happens when you use the overall speed/duration setting…i.e. you vary that and then all the keyframes move with it…
    Anyone have any ideas?
    Ta
