Activity Forums Adobe Premiere Pro time remap beyond 1000%?
  • time remap beyond 1000%?
    Posted by Kent Beeson on September 8, 2013 at 3:20 am
    Using PP CS6, how can I time remap up to past 1000% faster? When I drag the bar between the two time key frames, it only allows me to go to 1000% but I might need it to go to 8 or 9000%
    thanks
    K
    Marc Nibor replied 8 years, 10 months ago 3 Members · 2 Replies
  • Ivan Myles
    September 8, 2013 at 5:04 am
    The following functions can be used to change speed: Interpret Footage (works on an entire file), Speed/Duration (works on a clip), and Time Remapping (works on a portion of a clip). If one function does not meet your needs, two or more can be applied simultaneously to get a multiplier effect.
    Alternatively, you could apply Speed/Duration and/or Time Remapping to a nested sequence that contained a clip with its speed already increased.
  • Marc Nibor
    November 11, 2017 at 11:04 am
    The Question was from 2013. Right now ist almost 2018 and in my opinion there was still no satisfying answer.
    But since this post came out on top of a google search here’s a still not perfect but good solution that I found hidden in a quite long youtube video about the topic.
    1. Prepare your ramp as usual and speed it up to 1000%.
    2. switch to the razor tool and cut out the part where your footage is at 1000%
    3. now rightclick this part > klick speed/duration > set the percentage to whatever you want.
    4. move the part at the right (where you slow down again) to fill the gap.
    This is still not a perfect solution, since there is a “speed jump” at the point where your cut is…. but it is barely noticable.
