Activity Forums Adobe After Effects Expressions Time referencing
  • Posted by David Michael on March 2, 2009 at 7:44 am
    I’m wondering if anyone knows if it is possible to cite variable values from the past. Specifically, if the position of one layer is pick-whipped to the position of another layer (which is always changing), how could I say: position[0] + (position[0]’s value from one frame back’). Assuming position[0] is changing every frame. Thanks for your advice!
    David Michael replied 17 years, 6 months ago 2 Members · 2 Replies
  • Filip Vandueren
    March 2, 2009 at 8:53 am
    Hi David,
    for properties of layers you can simply use valueAtTime(time),
    so in your example:
    position[0] + position.valueAtTime(time-thisComp.frameDuration)[0];
  • David Michael
    March 4, 2009 at 12:48 am
    Hey thanks for that! Exactly what I needed.
    One more thing, if I have linear movement from point 0,240 at second 0 and I want a motion path to travel to 720,y at second 10 where y is a random point between 0 and 480, how could I set that up?
