Activity › Forums › Apple Final Cut Pro Legacy › Time Machine-like back-up Manager for multiple drives?
Posted by Max Frank on March 3, 2011 at 7:54 amHI,
I’m working on a project that is pulling from several FW 1TB drives.
For each drive, I have a back-up drive.
Is there any software similar to Time Machine that makes sure the backup drives are current and will reflect any of the changes I’ve made to the original drives?
Thanks in advance,
Wayne
Max Frank replied 15 years, 6 months ago 4 Members · 6 Replies -
Thomas Morter-laing
March 3, 2011 at 9:15 amUmm, pretty sure Time Machine allows you to back up external hard drives to a single external hard drive, as well as your computer.
Tom Morter-Laing
Freelance Editor
Certified Apple Product Proffessional, 2010
http://www.depictproductions.co.ukSony Z5, with Rode NTG2.
iMac 27″ intel i7 2.93GHz, 12GB RAM, ATI HD5750 [1GB GDDR5], 2TB Int. SATA with 2TB External HDD; (FW800), with Elgato Turbo H264HD. -
Max Frank
March 3, 2011 at 9:16 amHi Tom,
But can you have multiple instances of Time Machine backing up multiple drives simultaneously?
W
Thomas Morter-laing
March 3, 2011 at 9:21 amOh I see sorry- so you don’t want one backup working on everything, you want separate backups such as drive 2 backing up drive 1, drive 3 baking up drive 4 etc… Im sure there’s a system for this, I looked into it once but cant remember what I found. Presumably a software RAID mirroring isn’t quite what you want, I mean that wouldn’t let you look ‘back in time’…
Tom Morter-Laing
Freelance Editor
Jeff Greenberg
March 3, 2011 at 12:11 pmWayne,
Time machine only works on your boot drive – not external media.
I haven’t ever seen anything that monitors like Time machine – where it monitors and backs up on an hourly basis…and permits you to visually go back. For years, most backup software will do this, but you have to keep it running all the time – and it just adds an incremental backup.
But I suspect what you really want, is a Raid 5 – a set of several disks (usually 4) that use a percentage of room on each disk as redundancy information in case one of the drives die. You then replace the one dead drive, and it rebuilds the missing one. You can see solutions from GTech, Lacie and Drobo (amongst others.) This isn’t a backup – merely a live drive that is redundant. You will still need to backup media in the long term.
Best,
Jeff G
Apple Master Trainer
Avid Cert. Instructor DS/MC
Avid & Color Videos Vasst.com
Compressor Essentials Lynda.com -
Paul Jay
March 3, 2011 at 1:23 pmGet ChronoSync.
My fave backup/sync tool.
Just Syncs differences. Not complete copies again and again and again.. -
Max Frank
March 3, 2011 at 9:40 pmGents,
Thank you all for the tips – I’ll give Chronosync a look,
Wayne
