Activity Forums Apple Final Cut Pro Legacy Time line wont play the sequence?
  • Time line wont play the sequence?
    Posted by Vasja Mihelcic on December 6, 2012 at 4:29 pm
    Hello.
    I was manipulating with frames in Cinema tools to get smooth slow motion effect. From 59,98fps went to 23,98fps. After going back to fcp 7 i could play the clip in preview, but not on the time line. ..it moves 3 frames and stops. I tried different time line settings. Time line is set on clip settings: 1280×720 24fps…There is a catch but i have a block, it has to be simple as cake…i just forgot long time not used fcp.
    thx for any help
    Tikal
    Shane Ross replied 13 years, 9 months ago 2 Members · 4 Replies
  • Vasja Mihelcic
    December 6, 2012 at 5:34 pm
    I mean clip wont play on Time line…it moves 3 frames and stopes…
  • Shane Ross
    December 6, 2012 at 5:47 pm
    What are the clip settings? Codec? What are the timeline settings?
    Shane
    Little Frog Post
  • Vasja Mihelcic
    December 6, 2012 at 7:44 pm
    I exited the FCP 7 program and now it works fine…I could not do it before because i was exporting.
    I happend while using cinema tool for smooth slow motion. Preview worked fine, when putted on time line was just stucked.
    clip: 1280 x 720 24fps H.264
    Time line: HDV 720p 24 i also tried several other settings.
    Thanks for taking interest in my problem…
  • Shane Ross
    December 6, 2012 at 7:46 pm
    [Vasja Mihelcic] “clip: 1280 x 720 24fps H.264”
    BUZZZZZZZTT! Don’t use H.264 clips in FCP. EVER. Transcode to ProRes. If you want to edit H.264 native, use Adobe Premiere Pro.
    Shane
    Little Frog Post
