Activity Forums Adobe Premiere Pro time line won’t play in Premier Pro CS6
  • time line won’t play in Premier Pro CS6
    Posted by Peter Clarke on June 21, 2012 at 5:13 pm
    I can’t find anyone with a similar problem on any forum. I am trying to run trial CS6 Premier on a MacPro 2 x 2.4 GHz Quadcore with 8 gigs ram and ATI Radeon HD 5770, OS 10.6.8, and I can’t get anything to playback in the timeline. It plays for a few frames and stops. I render the timeline and still stops after a few frames. Is there some preference I need enable? CS5 runs same media (MP4) fine.
    I did send a sequence to AME and that plays fine.
    I logged in with Adobe ID. It opens and goes through a normal launch, asking whether new or existing project, etc. When I select either, it says “Licence software” or “continue with trial.” I select “trial” Is there a trial serial number I’m supposed to enter?
    Darva Campbell replied 11 years, 1 month ago 13 Members · 19 Replies
  • 19 Replies
  • Kevin Monahan
    June 22, 2012 at 7:28 pm
  • Peter Clarke
    June 22, 2012 at 9:04 pm
    Thanks. That did the trick.
  • Billy Mccreary
    August 20, 2012 at 8:42 pm
    This didn’t work for me. Finder, Spotlight or myself could not find the file.
    Any other suggestions?
    I’m on OSX 10.6.8 in Pr 6.0.1
  • Al Johnson
    September 23, 2012 at 7:01 pm
    I’m having the same problem (or similar). Since I installed CS6 the timeline won’t play even if I click the play icon. Also won’t play in CS5.5
    I don’t find that file in the Preferences folder either.
  • Tom Daigon
    September 23, 2012 at 7:16 pm
    1.Create a new sequence that has the same attributes of the one that wont play.
    2. Open the sequence that wont play and COPY.
    3. Go to NEW sequence and Paste.
    4. Hopefull that will fix it.
    I had this problem as well. Some think that the Player was retooled between 6.01 and 6.02. Hence the issue. It solved the media and playback issue on my system nicely.
    Tom Daigon
    PrP / After Effects Editor
    http://www.hdshotsandcuts.com
    https://www.youtube.com/watch?v=XRIg6h-LIm0 (Best viewed at 1080P and full screen)
    HP Z820 Dual 2687
    64GB ram
    Dulce DQg2 16TB raid
  • Al Johnson
    September 23, 2012 at 7:31 pm
    Thanks Tom, but that didn’t do it. I noticed you mentioned ver 6.01 and 6.02
    My version is 6.0.0 and it was just delivered two days ago so i figured it was the latest version. Maybe I should look for 6.0.2 update?
  • Tom Daigon
    September 23, 2012 at 7:35 pm
    Well, its always good to be current for bug fixes (in most cases) but the fact that the cut/paste issue didnt help suggests to me it might be a completely different issue.
    Tom Daigon
    HP Z820 Dual 2687
    64GB ram
  • Al Johnson
    September 23, 2012 at 7:44 pm
    Thanks, I’ll try the update. Every “brand new” product in my just purchased CS6 Production Premium Suite needs to be upgraded so I’m sure it’ll take awhile. I’ll update when it gets resolved.
  • Genaro Amaral
    October 31, 2012 at 3:34 am
    I dont know why, but the same problem has fixed itself here after i saved the project in a external HD…
    Im really happy about it. Hope it works for you too..
  • Jon Simms
    November 4, 2012 at 10:09 pm
    Hi Al Johnson,
    Did you ever resolve this?
    Having a similar issue, and after days of trouble shooting, I haven’t solved it.
    J
