Time line output to NTSC monitor
Posted by Jimesyco on January 4, 2006 at 11:10 pmI am trying to output a file I have in my timeline in Vegas 5 to an NTSC Monitor so I can advance my timeline frame by frame and see it in my NTSC monitor. For the life of me I can’t figure out how to do this.
can anyone give me step by step instructions?
Jimesyco
Seatlanta replied 20 years, 7 months ago 5 Members · 9 Replies -
Edward Troxel
January 5, 2006 at 2:51 am -
Jimesyco
January 5, 2006 at 3:30 amYes, but this only will play the video file in print video to Dv mode. An option under tools. You can not pause the video and advance it frame to frame. It just plays (prints to dv) or you can cancel it. On or off.
I am trying to advance my timeline “frame by frame” and see it in my NTSC monitor. I am thinking there is a selection or tool somewhere in the software but I can’t find it.
Can you assest me further in a way I can advance the file in the time threw the NTSC monitor frame by frame (like control it with the left and right arrows keys advancing frame by fram)?
Thanks Jim
Edward Troxel
January 5, 2006 at 4:41 amIf you click on the External Preview button, it will show wherever the cursor is located on the external monitor. Just use the left right arrows (Hold ALT down for frame by frame) to move frame by frame on the external monitor. I am NOT talking about Print to Tape – I’m talking about External Preview.
Dave Petteruto
January 17, 2006 at 6:18 pmIf you don’t want to use a camera in the “camera/convertor/deck” link of this chain, what is the most ecconmical way to go? Are there other things out that are cheaper than something like a “Canopus ADVC110”?
Edward Troxel
January 17, 2006 at 10:25 pm -
Jeremy Rochefort
January 18, 2006 at 8:07 amI must concur with Edward on this, DONT be cheap on this one.
I have setup systems for people and the Canopus ADVC 110 (or better) has always given consistent results (and fairly good quality as well). Besides, the ADVC can then also be used for non-dv capture of footage (from a VHS machine for example) for conversion to dvd for customers
Cheers
Jeremy
MJ Productions
Dave Petteruto
January 18, 2006 at 7:18 pmSince this is all pretty new to me I just want to be sure–Using a Canopus ADVC110 in place of a camera I will be able to view my timeline on an external television or monitor.
Thanks for all your help. -
Edward Troxel
January 18, 2006 at 10:27 pm -
Seatlanta
February 2, 2006 at 3:19 amI’ve used several converter boxes and the less expensive ones have not been satisfactory. I’m presently having problems with the ADS box. It worked for a while after I bought it, but soon became erratic.
Another low-cost convertor box works better, but is still not as stable as I want it to be.
I have just bought the Canopus box. I have not tried it yet, but if it works, it will be money well spent. I’ve watched hours turn into days as I tried to do a simple transfer to or from tape with the other boxes.
We’ll see.
James (seatlanta)
