  • Posted by Rpaluso on August 22, 2006 at 12:29 am
    just got a new Sony HDR-HC3 cam. loving it. but trying to do a time lapse on FCP. the camera for interval setting is only done with the digital camera function. so it will take a frame every minute. used the function for 120 min…so came up with 120 images. how do i edit this down to create a smooth time lapse with the images rather than using a film clip?
    Rpaluso replied 20 years, 1 month ago 3 Members · 3 Replies
  • Jerry Hofmann
    August 22, 2006 at 2:54 am
    Import the stills into FCP after you set the still frame duration to 1 frame in the FCP user preferences. Then edit them in a sequence by dragging them all to one. Render…
    Jerry
  • Peter Mcauley
    August 22, 2006 at 1:02 pm
    Or use quichtime pro, open them as an image sequence then render it to the codec of your choice. This way you have an actual clip to work with in FCP or any other app.
    Peter McAuley
    Axyz Edit
    Toronto
    G5 dual 2.0
    4 gigs ram
    10.4.3
    FCP 5.04
    QT 7.03
    Kona 2 v1.1.4 with K Box
    4 X 250 gig external F800 Lacie firewire drive
    2 X 23″ Apple cinema display
  • Rpaluso
    August 27, 2006 at 2:17 am
    what about capturing footage? if i had a clip of footage (say a sunset) that i wanted to speed up by time lapse…Can you capture one frame per second? is there a setting to do that?
