Activity › Forums › Avid Media Composer › time lapse
  • time lapse
    Posted by Marcus200 on May 8, 2006 at 12:57 pm
    Just need the perspective of some top notch editors here…
    Tomorrow, I have to shoot a construction crew assembling a building for a car dealership. A time lapse sequence of this process is desired by the client.
    I have to shoot this with an Ikegami Betacam, so I have no frame grab hardware or anything that resembles an intervalometer.
    How should I shoot this? I’ll need to be on site w/camera locked down for about 8 hours. How often should I roll tape and for how long? This will be eventually cut on an Avid.
    thanks.
    Geraint Pari huws replied 20 years, 4 months ago 3 Members · 3 Replies
  • Kenton Vannatten
    May 8, 2006 at 4:50 pm
    I think it would depend on
    a) how long the construction will take (is it only going to be the 8 hrs? or will it be multiple days?)
    b) how long does the client want the overall Time Lapse to be in the final edit
    c) will you be speeding up the footage or just showing a bit here and there in real-time?
    Kenton VanNatten
    Avid Editor (for hire)
  • Kenton Vannatten
    May 8, 2006 at 4:53 pm
    But as a general guide I’d roll for 15 mins or so every 30 mins??
    Kenton VanNatten
  • Geraint Pari huws
    May 8, 2006 at 11:12 pm
    shoot first minute, leave camera locked off, treat yourself to a very long lunch, go back and shoot last minute, load to avid, mix from one to another, if nothing changes apart from the light then the story’s not worth following!
    Or, follow the advice in thread, but when you’re loading back to avid load wild with no code at your on-line resolution with the beta running at full rate dmc.
