Activity › Forums › Adobe After Effects › time flicker?
time flicker?
Posted by Jeremy Webb on January 11, 2006 at 10:57 pmi thought there was an effect call time>flicker. but i think i must be thinking of fcp. so how do i make an image turn on and off at an interval?
Aharon Rabinowitz replied 20 years, 8 months ago 3 Members · 2 Replies -
Dan Ebberts
January 12, 2006 at 12:04 amYou probably want the Strobe Light effect with the “Make Layers Transparent” option.
Dan
Aharon Rabinowitz
January 13, 2006 at 3:51 amMan, I hate that effect. It works based on time, not frames so it’s a bit unpredictable, and hard to tweak. Thanks heavens guys like Dan Ebberts have made expressions easy to understand because…
I did a tutorial on making a TV screen, and in it I cover making a flickering white bar – maybe that will help you, since it uses 3 keyframes and an expression to make it flicker – takes a minute to set up, if even that. You can easily adapt it to your footage.
the tutorial is here:
https://www.creativecow.net/show.php?page=/articles/rabinowitz_aharon/old_tv/index.html
Aharon Rabinowitz
aharon(AT)yahoo(DOT)com
http://www.allbetsareoff.com
Creative Cow Master Series DVD
particleIllusion Fusion Volume 1
available @ http://www.pIllusionFusion.com
