Activity Forums Adobe After Effects Expressions time expression
  • Posted by Yaniv Cahoua on November 5, 2020 at 4:46 pm
    Hey everyone !
    Anyone knows if there is a way to do something like this:
    If a value is above zero start playing a video from start ( with time remap), else stop.
    Meaning everytime a character talks I can have the content of the video played from the start each time.
    we are doing a split screen, and I need to have 2 logos animating once from start each time one of two characters talking and I find a bit tiedious to make it by hand as there are many layers that need this treatment.
    Thanks !
    Yaniv Cahoua replied 5 years, 10 months ago 2 Members · 6 Replies
  • Dan Ebberts
    November 5, 2020 at 6:38 pm
    Something like this might work. Adjust the threshold value to what works best for you:
    aud = thisComp.layer("Audio Amplitude").effect("Both Channels")("Slider");
    threshold = 5;
    val = 0;
    if (aud.value > threshold){
    t = time - thisComp.frameDuration;
    while (t > 0){
    if (aud.valueAtTime(t) < threshold) break;
    t -= thisComp.frameDuration;
    val = time - t;
    val
  • Yaniv Cahoua
    November 5, 2020 at 9:04 pm
    oh this is great ! thanks so much.
    I am trying now to adapt your expression to not start from 0 each time and I thought removing val =0; would be enough but I get an error…
    any chance you provide a solution also for this one.
    oh I wish I could solve this alone but my maths are a bit rusted
  • Dan Ebberts
    November 5, 2020 at 9:54 pm
    I think this is what you mean. Just adjust tStart to where you want playback to begin:
    threshold = 5;
    tStart = 1;
    val = tStart;
    while (t > 0){
    val += time - t;
    val
  • Yaniv Cahoua
    November 5, 2020 at 10:19 pm
    when the voice goes down, I need the comp to stay where it is and then continue from there when the sound goes up again I need the video to continue playing from the same point
    currently when the sound goes down the video is going to a fixed timecode
    I need Val to not be set to 0 at the start of each frame.
    I don’t want it to be a loop any more, I want it to be on offset mode (as if using loopOut)
    I have another video that don’t need to be looped.
  • Dan Ebberts
    November 5, 2020 at 11:04 pm
    That’s quite different. This should work, but it might become a processor hog if your comp gets too long:
    threshold = 5;
    tStart = 0;
    runFrames = 0;
    f = timeToFrames(time);
    while (f >= 0 ){
    if (aud.valueAtTime(framesToTime(f)) > threshold){
    runFrames++;
    f--;
    tStart + framesToTime(runFrames)
  • Yaniv Cahoua
    November 6, 2020 at 7:44 am
    thiis is brilliant thanks so much.
    I thought it would be much more easier, but the way you count the frames was actually not easy enough to find by myself
