Activity › Forums › Adobe After Effects Expressions › Time Delay Expression
  • Time Delay Expression
    Posted by Per on May 26, 2005 at 11:27 am
    I need some help with an expression. I have a sequence with a golden football which is traveling in 3D space. I want to have a tail or a tunnel of rings after the football. The rings should born from the football and then scale up a bit and finally disappear (opacity: 0), it should be 5-8 frames between each ring and they have to track the x,y,z position of the football.
    Anyone have a good solution for my problem?
    Thanks in advance
    Mylenium replied 21 years, 4 months ago 3 Members · 2 Replies
