Activity › Forums › Panasonic Cameras › Time Code with firewire capture
  • Time Code with firewire capture
    Posted by John Murphy on August 3, 2007 at 6:22 pm
    I’m using Final Cut 6.
    I capture directly into Final Cut via a MacBook Pro. I have a firewire drive connected to the MacBook.
    I can’t get time code when capturing this way.
    If I use the DVCPRO firewire capture setting, and click on “Capture Now”, I get a message, “Waiting for timecode.
    If I use “Uncontrollable device”, I can capture but without timecode.
    Is it possible to capture via firewire and get timecode?
    Thank You,
    John
    John Murphy replied 19 years, 1 month ago 2 Members · 2 Replies
  • Shane Ross
    August 3, 2007 at 6:27 pm
    What are you capturing? if you are capturing DV, then the DVCPRO setting is not for you. Choose the DV/NTSC (or PAL if you are in Europe) EASY SETUP and use that.
    Shane
    Littlefrog Post
    http://www.lfhd.net
  • John Murphy
    August 3, 2007 at 11:11 pm
    I’m capturing 1080 60i DVCPRO HD.
    I used easy setup for the correct settings.
