Activity › Forums › Avid Media Composer › time code breaks
time code breaks
Posted by Davidblumenfeld on November 19, 2007 at 7:24 pmHi. I am trying to digitize to an Avid my DVX100A footage shot on 25P PAL (squeeze). It keeps stopping with a Time Code Break in the middle of scenes! ANY SUGGESTIONS?? THANKS>
John Cuevas replied 18 years, 10 months ago 4 Members · 4 Replies -
Jon Zanone
November 20, 2007 at 11:57 amDo you have ‘digitize across time code beaks’ selected in settings / deck preferences?
Jon
“So you want to throw out the old you – but the old you is old enough to know it won’t make it better”
Del Amitri – “Make it Better” -
Fred Williams
November 20, 2007 at 2:26 pmIt is not in the deck preference, it is in your project bin under settings, capture and the general tab.
Davidblumenfeld
November 20, 2007 at 6:18 pmtried that…didn’t help…it happens in the middle of shots, sometimes, and between shots a lot of the time.
John Cuevas
November 20, 2007 at 8:15 pmMake sure you aren’t running anything else while digitizing. On one of my systems, I can’t log, batch dig and then cruise the Cow…the other system can’t handle it.
If that isn’t the problem, couple of options – try control track. Or black another tape, lay the footage to that tape…then you know you have a pristine time code.
If you are using a tape that’s been used a few times, TC can get a little wierd.
