Activity Forums Adobe After Effects Expressions Time change between two points
  • Time change between two points
    Posted by Chris Craig on December 19, 2014 at 4:01 am
    Hello everyone
    I am making an animation that has a 2 points, A & B at opposite ends of the frame (horizontal). Inbetween the 2 points, is an text layer with numbers (minutes and seconds). When i move the text layer closer to point A, I would like the numbers to decrease in time and when the text layer moves closer to point B, I would like the numbers to increase in time to the point where B = 1hr 15min 00secs.
    I appreciate anyones input.
    All the best and have a merry christmas.
    Chris
    Kevin Camp replied 11 years, 9 months ago 2 Members · 3 Replies
  • Kevin Camp
    December 19, 2014 at 6:28 pm
    see if this works for you:
    xA = 100; // x value for point A
    tA = 0; // time value for point A in hours
    xB = 1000; // x value for point B
    tB = 1.25; // time value for point B in hours
    v = linear(position[0],xA,xB,tA,tB)*60*60/thisComp.frameDuration;
    t = timeToTimecode(framesToTime(v)).split(':');
    hr = t[0].split('').[1];
    min = t[1];
    sec = t[2];
    hr+'hr'+' '+min+'min'+' '+sec+'secs'
    set the xA and xB values as needed for the x values of points A and B. You didn’t mention a time values for point A, i assumed zero, but you can change if needed.
    since the expression uses the timeToTimcode() function, it is limited to 3 hours max, but this method makes it a little easier to get leading zeros for minutes and seconds, which I think you want. if the 3hr limit doesn’t work, there are other ways to get that formatting that aren’t limited to 3hrs.
    Kevin Camp
    Art Director
    KCPQ, KZJO & KRCW
  • Chris Craig
    December 20, 2014 at 1:41 am
    Thanks a lot Kevin
    I applied your code, but it returns a syntax error in line 10.
    Am i doing something wrong. I have AE cc
    Yes, the time does start at zero.
    Thanks a lot.
  • Kevin Camp
    December 22, 2014 at 5:39 pm
    Sorry Chris, there was an inadvertent period in the tenth line, change it to this:
    hr = t[0].split(”)[1];
    Kevin Camp
    Art Director
    KCPQ, KZJO & KRCW
