Activity Forums Adobe After Effects time change audio expression
  • time change audio expression
    Posted by Peter Meier on May 21, 2011 at 11:05 pm
    Hi there
    I made a from my audio some keyframes to animate a layer.
    -> thisComp.layer("track1").effect("Both Channels")("Slider")
    is it possible, to add to this expression some values to influence the behavior?
    it’s working and it’s fine but I would like to slow down the animation a little…
    so is it possible to do it like this?:
    thisComp.layer("track1").effect("Both Channels")("Slider")+time*10
    or how can I change this expression to slow down the change of the values through the audio…?
    thx
    Walter Soyka replied 15 years, 3 months ago 2 Members · 1 Reply
  • Walter Soyka
    May 21, 2011 at 11:58 pm
    You might get better answers on this in the After Effects Expressions forum [link] — but I’d either use time-remapping [link] or valueAtTime [link]:
    thisComp.layer("track1").effect("Both Channels")("Slider").valueAtTime(time/2)
    This would run at half-speed; obviously, you could change the time/2 in the expression above to adjust the rate.
    Walter Soyka
