Tiling Vector Art (with RepeTile)
Hello all, I hope one of you can help me out.
I’m working on a composition in which the camera ‘zooms’ into a large tiled grid of the same object. At the moment, I have one composition (let’s call it CompA) which contains animated vector art. Just some simple transformations.
I then place this into a the final comp (CompB) and place a CC RepeTile effect on it. I adjust the effect to fill the screen with CompAs. I then create ‘zooming’ animation (just increasing scale over time) into the center object.
Problem is, when I turn on Continually Raster for the CompA layer, the tiling effect turns off, just leaving me with one object. The amount I’m scaling CompA is extreme, which is why I’m using vector art.
How can I get Continually Raster-ed vector art and CC RepeTile to work with each other?
Thanks in advance!
Devin Hunt
Field Union
