Activity Forums Maxon Cinema 4D Tile Camera order
  • Tile Camera order
    Posted by Dennis Miller on April 11, 2006 at 1:44 pm
    Greetings. I’ve got a scene that will not render due to memory limitations (despite having 4 GB on board!).I tried the 9 Tile camera, and it only rendered a portion of the scene – a small region in the lower center of the image, about 1/6 of the entire scene. It also scrambled the frames quite a bit, and when I stitched them back together, they were in the following order:
    7 3 0
    4 2 1
    5 6 8
    I am going to try this again with the 25 Tile Cam and I wonder if anyone knows what arrangement that will produce…
    Also, any thoughts on why the 9 Tile Cam only rendered a portion of the scene? There was no camera in the scnee previously, and I simply inserted the 9 Tile Cam as an object, selected it as the current scene cam, enabled Tiling in the Exp Tag, and rendered frames 0 – 8. Quite frustrating all in all.
    Thanks for any suggestions.
    Best,
    Dennis
    Dennis Miller replied 20 years, 5 months ago 1 Member · 0 Replies
  • 0 Replies
