Activity › Forums › Apple Final Cut Pro Legacy › Tight Deadline!! FCP 6 to HDCam SR question
Posted by Abie Silva on January 4, 2012 at 7:06 pmGoing to tape from final cut pro 6 HDCam SR deck is adding an extra frame of black at the end. If anybody can shed some light on this will be much appreciated.
Abie Silva replied 14 years, 8 months ago 2 Members · 5 Replies -
Shane Ross
January 4, 2012 at 7:23 pmWhat capture card? Not that it matters much…I had the same issue with FCP 6. Which is why I couldn’t do a reliable INSERT EDIT, unless I went all the way to the commercial break (black)…or all the way until the end. But that was an earlier FCP 6…are you updated to 6.0.6?
Shane
Little Frog Post
Read my blog, Little Frog in High Def -
Abie Silva
January 4, 2012 at 7:35 pmUsing Final cut pro 6.0.6. We have a 45 minute program and our insert is at 20 minutes in did you ever find another solution for the issue. Thank You so much for the speedy reply
Shane Ross
January 4, 2012 at 7:41 pmAgain…what capture card are you using? This for me was solved by updating to FCP 6.0.6, and the latest version of my capture card software. At the time I was running an AJA KONA 3…forget the software version of that one..
Shane
Little Frog Post
Abie Silva
January 4, 2012 at 7:58 pmYeah were just gonna digitize the entire program, insert & relay back to tape. We wud appreciate anyone ele’s input on this issue. thank you all for your help
