Activity › Forums › Apple Final Cut Pro Legacy › Tiger, FCP HD, Diigital Cinema Desktop Preview Not Working!
  • Tiger, FCP HD, Diigital Cinema Desktop Preview Not Working!
    Posted by Tangier Clarke on May 4, 2005 at 10:03 pm
    Just wondering if anyone has had this problem, but now that I have Tiger, my digital cinema desktop preview will not play. I single frame will show up (External Video: All Frames turned on)
    but pressing the space bar does nothing.
    Tangier
    Michaelle Stikich replied 21 years, 4 months ago 7 Members · 13 Replies
  • 13 Replies
  • Fx Bear
    May 4, 2005 at 10:18 pm
    My guess the upgrade or update of your OS seems to change your system settings. Try trashing your prefences files and Easy-Set up files, then re-launch FCP. If that doesn’t work you may have to delete FCP and re-install. Not a fun sollution but it works.
  • Tangier Clarke
    May 4, 2005 at 10:41 pm
    I’ve already done a full uninstall/reinstall – same results.
    Tangier
  • Steve Eisen
    May 5, 2005 at 12:09 am
    By chance, make sure your windows in FCP do not overlap. Press Ctl U. Also make sure your Viewer and Canvas Window are set to Fit to Window.
    G5 Dual 2.5 160GB System 400GB Media Drive ATI 9800 256MB 6 GB RAM
    Dual Gig Quicksilver 1GB RAM 80 GB System drive (3) 250 GB internal media storage
    15″ Al Powerbook 1.25 1GB RAM
    OS 10.3.8 FCP 4.5, DVDSP 2, QT 6.5, Boris Red 3GL 1.65 TB External Stor
  • Solie Swan
    May 5, 2005 at 4:39 am
    Same problem here. Done the delete prefs thing but still not working.
  • Sean Lander
    May 5, 2005 at 8:26 am
    I had already posted this bug. If you have only one monitor then your stuffed. If you have two you can use the monitor that does not have the menu bar. Or you can control full screen playback if the canvas window is on the other screen. Hopefully this bug will be fixed soon.
  • Kevin Monahan
    May 5, 2005 at 5:58 pm
    Funny. It’s working just fine for me.
    Kevin Monahan
    Author – Motion Graphics and Effects in Final Cut Pro
    fcpworld.com
  • Michaelle Stikich
    May 5, 2005 at 6:20 pm
    So did you do a complete tiger install or an archive and install? When I look in my Library/Quicktime folder I see these pieces: DesktopVideoOut
    FCP Uncompressed 422
    If they are not there, Digital cinema desktop won’t work.
    So something might have gotten botched in the archive install. And when you say complete uninstall, do you mean Tiger or FCP?
    gir
  • Tangier Clarke
    May 5, 2005 at 6:53 pm
    I did an uninstall of FCP HD. My Tiger installation is a clean install – I archived my previous system folder as not to lose it.
    Frankly I don’t use Digital Cinema Display on my desktop that much, only to the Sony WEGA. However I’d like to know that it does work when I want it to.
    Tangier
  • Kevin Monahan
    May 5, 2005 at 7:04 pm
    Tangier,
    Sounds like some of your crucial QT components got moved when you upgraded to Tiger. You should uninstall your current version of FCP, then reinstall it to get everything back in the right place.
    These articles should help you:
    Final Cut Pro HD: How to Uninstall
    https://docs.info.apple.com/article.html?artnum=93811
    Final Cut Pro 4: How to Uninstall
    https://docs.info.apple.com/article.html?artnum=93150
    Kevin Monahan
    fcpworld.com
  • Sean Lander
    May 6, 2005 at 2:58 pm
    Yep I have that in my library. For what it’s worth I did an UPGRADE so in theory nothing should have been moved.
    This has happened now on 3 computers that have been upgraded with Tiger. I will try and uninstall and then re-install and see what happens.
