Activity Forums Avid Media Composer Tiff sequence won’t playback in XpressPro?
  • Tiff sequence won’t playback in XpressPro?
    Posted by Chris Foogs on August 7, 2008 at 11:35 am
    Hi all,
    I have imported a Tiff sequence into AXP using the default settings (DV25).
    In each sequence there are about 700 files for about 20-30secs worth of footage and the TIffs are about 3.5mb each.
    Once imported the sequence refuses to playback – it will move jerkily a couople of times and then just skip to the end of the sequence.
    It looks as though the machine just doesn’t have enough grunt – could this be the case? Or maybe there are settings I could alter?
    I’m going to convert the pics to Jpeg to hopefully alleviate the problem, but will I lose picture quality?
    Thanks all.
    Jakub Vansa replied 18 years, 1 month ago 4 Members · 3 Replies
  • Jon Zanone
    August 7, 2008 at 11:50 am
    What are your system specs?
    Jon
    “So you want to throw out the old you – but the old you is old enough to know it won’t make it better”
    Del Amitri – “Make it Better”
  • Job Ter burg
    August 7, 2008 at 12:45 pm
    Sounds like a display problem, sometimes caused by ill placed windows. Will other footage play back correctly? Click on your source/rec monitor and hit CTRL + ‘ or CMD + ‘.
  • Jakub Vansa
    August 7, 2008 at 11:02 pm
    I think converting to jpg will not help you, because Avid makes its own media files… Are you sure about proper resolution? Because some very good resolution such as 1:1 could make you trouble during playback due to its very high data rate.
