Activity › Forums › Apple Final Cut Pro Legacy › .tif resolution when freezeframed in fcp 5
  • .tif resolution when freezeframed in fcp 5
    Posted by Jeremy Amaudruz on November 23, 2009 at 9:14 pm
    I am threading together slides transferred into .tif to make a slideshow using fcp 5. The image quality on playback is below that of iphoto when viewed from a smaller size to full screen on a 15” monitor. Why? If the answer could be deemed technically challenging then how could the quality be bettered?
    I have some notion that I need a reference monitor or that I should offline to tape or burn a dvd in order to see the actual results of my edit but then why can iphoto do what fcp, apparently, cannot.
    thanks
    jeremy
    Rafael Amador replied 16 years, 10 months ago 5 Members · 4 Replies
  • Aaron Neitz
    November 23, 2009 at 9:25 pm
    1) are you viewing in RT / Did you render? Stills can be awfully awful when you haven’t rendered them in the timeline.
    2) SD timeline or HD timeline?
  • Alan Okey
    November 23, 2009 at 9:56 pm
    Jeremy,
    What size are your stills? FCP is designed to work at video resolutions, which would be 720×480 (or 720×486) at Standard Definition or either 1920×1080 or 120×720 at High Definition. If you want to make a project that matches the resolution of your stills, you need to manually change the project dimensions in the Sequence Settings dialog box.
    If your stills are larger than HD resolution, or if you’re working in an SD project, obviously your project output won’t look as sharp as the original iPhoto slide show.
  • Steve Eisen
    November 23, 2009 at 10:25 pm
    Your assumption is right Jeremy. You can not judge the quality on your computer monitor.
    Steve Eisen
    Eisen Video Productions
    Board of Directors
    Chicago Final Cut Pro Users Group
  • Rafael Amador
    November 24, 2009 at 11:43 am
    And you are not working in a DV or so time-line, don’t you Jeremy?
    rafael
    http://www.nagavideo.com
