Activity › Forums › Apple Final Cut Pro Legacy › tif Files as Unkown Files in FCP!!
  • tif Files as Unkown Files in FCP!!
    Posted by Mike Koslap on April 11, 2008 at 1:49 pm
    For some reason FCP 6.0.2 won’t recognize any .tif files I try to import for a project.
    I’m using a standard NTSC project setup in FCP and my .tif files include layers, alpha channel, no compression, Mac Byte Order, and RLE layer compression.
    I’ve used both Photoshop CS 8.0 and CS3 and both haven’t worked.
    Bob Auiler replied 18 years, 5 months ago 4 Members · 3 Replies
  • Aaron Neitz
    April 11, 2008 at 2:32 pm
    … could be mistaken, but I’d assume FCP won’t support tiffs that have layers enabled. Tried flattening them? Or just use psd files if you need layers
  • Walter Biscardi
    April 11, 2008 at 2:57 pm
    I believe you have to turn off layers in TIF’s, they need to be flat.
    We ran into this issue with an animation that was delivered to us as a TIF sequence. FCP would not read the files so I sent them into After Effects and rendered out a Quicktime movie.
    Walter Biscardi, Jr.
    Biscardi Creative Media
    HD and SD Production for Broadcast and Independent Productions.
    STOP STARING AND START GRADING WITH APPLE COLOR Apple Color Training DVD available now!
    Read my Blog!
    View Walter Biscardi's profile on LinkedIn
  • Bob Auiler
    April 11, 2008 at 4:29 pm
    They’re probably CMYK.
    Bob Auiler | bob.auiler@mvpcollaborative.com
