Activity Forums Adobe After Effects Expressions Tie one property to another with pick whip but have the layer take say 10 frames longer
  • Tie one property to another with pick whip but have the layer take say 10 frames longer
    Posted by Lori Newman on December 10, 2013 at 1:55 am
    Hi Everyone,
    I am trying to learn how to do a simple thing with expressions. In this case with scale, but in general if I have a few layers and I pick whip the scale properties to one layer that has 2 scaling keyframes, what syntax do I add to the other layers in the expression if I want them to come in say 10 frames later than the object they are pick whipped to? Thanks in advance.
    Lori
    Lori Newman replied 12 years, 9 months ago 2 Members · 5 Replies
  • Dan Ebberts
    December 10, 2013 at 3:50 am
    valueAtTime() is what you’re looking for. This should give you a 10-frame delay:
    delay = framesToTime(10);
    thisComp.layer(“other layer”).transform.scale.valueAtTime(time-delay);
    Dan
  • Lori Newman
    December 10, 2013 at 4:30 am
    Thank you Dan.
  • Lori Newman
    December 10, 2013 at 5:12 am
    Thank you.
    This works great. The only problem that I’m having is that the objects are lining
    up (position in this case). How do I have one follow the other without landing on top
    of the object that is being followed, so that it keeps it’s position but is a few steps behind
    in time?
  • Dan Ebberts
    December 10, 2013 at 5:43 am
    That’s a little trickier. I think the examples at the bottom of this page will help:
    https://www.motionscript.com/mastering-expressions/follow-the-leader.html
    (see the A Completely Different Approach section).
    Dan
  • Lori Newman
    December 10, 2013 at 5:53 am
    Thanks for your help. I’ll give it a try.
