Activity Forums Adobe After Effects tic tac – ‘growing’ circle to indicate secounds
  • tic tac – ‘growing’ circle to indicate secounds
    Posted by Wim Roegels on March 9, 2007 at 4:44 pm
    I have a comp taking 20min with an countdown and I would like to visualize the secounds.
    What I have is a solid with a mask growing and shrinking the shape of the mask with two keyframes.
    How can loop these keyframes automatically? Unfortunatly I can not add any expression to the shape (‘loop_out(
    Wim Roegels replied 19 years, 6 months ago 2 Members · 6 Replies
  • Kevin Camp
    March 9, 2007 at 5:11 pm
    since you can’t add expressions to masks, i think you need to pre-comp you mask animation, set that comp to the length of your loop, then try your loopout expression on then now nested pre-comp.
    Kevin Camp
    Designer – KCPQ, KMYQ & KRCW
  • Wim Roegels
    March 9, 2007 at 5:29 pm
    you mean with using time remapping keyframes and a loop expression, right?
    Best regards
    wim
  • Kevin Camp
    March 9, 2007 at 6:01 pm
    correct, enable time remapping for your nested pre-comp and enter: loopOut(“cycle”,0). then extend the layer’s end point to the length of the comp.
    Kevin Camp
  • Wim Roegels
    March 9, 2007 at 6:40 pm
    thanks kevin.
    Best regards
    wim
  • Wim Roegels
    March 10, 2007 at 10:50 am
    Sorry to bother, but I have to ask again – unfortunatly the loop does not work.
    What I have done …
    o Precomp the mask animation (duration 1sec)
    o placed the mask ani comp in my main clock comp
    o Enabled time remapping
    o Added two keyframes: 1st at 00:00 with value 00:00 and 2nd at 01:00 with value 01:00
    o Added expression “loopout(“cylce”,0)”
    Where is my mistake?
    Best regards
    wim
  • Wim Roegels
    March 10, 2007 at 12:52 pm
    the comp with the second animation was not the same length as the comp I placed it in.
    So I extended the lenght, applied the expression ‘loop_out(“cycle”,0)’ and now it works.
    Thanks.
    Best regards
    wim
