Activity › Forums › Adobe Premiere Pro › Thumbnails keep refreshing. Slow response time.
Posted by Xavier De champs on May 16, 2006 at 12:50 pmWhy do my thumbnail refresh every 2 minutes? It
Xavier De champs replied 20 years, 3 months ago 2 Members · 3 Replies -
Vince Becquiot
May 16, 2006 at 8:13 pmWell it could just be that the cpu is maxing out. How many hard drives do you have ?
It is always best to separate your OS from your capture files (Including images, especially if they are high rez), and possibly your preview files as well, so basically 3 hard drives.
Cheers,
Vince
Xavier De champs
May 17, 2006 at 8:07 amI have the Video on an external USB2 disc, and the video and preview and conformed audio on an internal disc (D), and the software on internal disc (C).
Xavier De champs
May 17, 2006 at 8:11 amI have noticed that the thumbnails are updating the POSTER FRAME to the IN point set in the SOURCE window. This is ok, but I see that about every third time I set an IN point in a clip, about half of the thumbnails in that bin all update. I would like to disable the automatic POSTER FRAME IN POINT, that happens when I set an IN point. In PP1.5, I recall, the POSTER FRAME only changed when I set the POSTER FRAME in the PREVIEW window. Can I disable this Automatic feature? Maybe in some .INI file or something?
