Activity Forums Apple Final Cut Pro Legacy Thumbnail images in bins
  • Thumbnail images in bins
    Posted by Zach Macdonald on August 6, 2009 at 7:08 pm
    I’ve a sequence that requires many still images. As such, there are several bins containing stills. Because there is a huge number of stills, i have every bin opened as a tab in the browser. Issue here is that each time I switch between tabs all the thumbnails have to redraw. This is resulting in huge time delays.
    The photos are all High-Res TIFF’s weighing-in in the ballpark of 20Mb…
    Suggestions on workarounds.
    (2 x 2.8 Quad Xeon, 8 GB Ram)
    David Johnson replied 17 years, 1 month ago 2 Members · 1 Reply
  • David Johnson
    August 7, 2009 at 1:24 am
    Maybe there’s a better way, but I’m not at my FCP machine now so the first thing that comes to mind is I’d use any method that doesn’t require a thumbnail view inside FCP … use list view in FCP and a thumbnail view in a Finder window to locate your images … or even Adobe Bridge, if you have it.
    If you must use thumbnails in FCP, perhaps separate out your various bins to their own windows and minimize them when not needed.
