Activity Forums Maxon Cinema 4D Thumb wheel scroller "button" – anyway to change the color?
  • Thumb wheel scroller "button" – anyway to change the color?
    Posted by Steve Bentley on September 8, 2021 at 8:43 pm
    I’ve been searching in the interface color choices to try and make that little scrubber button that lets you scroll up through lists stand out better – it’s virtually invisible (with a ton of objects in the list) since it’s only half colored, not to mention too small. Can anyone give me a hint?
    Pretty dismayed to comeback and see the UI hasn’t gotten any better (I wonder at what point the “visibility buttons” will become a single pixel? Software makers do realize that as the screens become more hirez the icons gets smaller right?) Things that are hard to hit take time to hit. If you want to work fast, these impossibly small buttons need to be a little larger and more visible. (not to mention reducing the eye strain trying to see them)
    I just went back to an earlier version and this thumb scrubber is much larger and fully colored (the current version is like a messed-up attempt at making it look 3D – hint, don’t make the “dark side” of the object the same color as the background) The older versions are much more visible and easier to hit.
    Steve Bentley replied 4 years, 12 months ago 1 Member · 0 Replies
  • 0 Replies
