Activity Forums VEGAS Pro Three Qs about Sony Vegas Pro 9
  • Three Qs about Sony Vegas Pro 9
    Posted by Jon Accarrino on March 16, 2012 at 5:16 am
    Hi all. Three things I would like to be able to do
    1) Assign a keyboard shortcut to “Render As” from the file menu. I couldnt find a way to do this, as I was able to assign other keys. That command does not appear to be in the list. Anyway to do this?
    2) If I have several empty audio tracks that I create, and several audio files in the media bin, and I want to move each file to it’s own track, can I in one fell swoop? The only way I see to do this is one at a time. If I grab all of the audio files, they all go onto one track. Any way to get each audio file onto it’s own track?
    3) Is there a way to use the Vegas Native plugs (particluarly the wavehammer plug) with other sw? I would like to use this plug with Cubase, but Cubase does not recognize the .dll file, even tho i poing Cubase’s plug-in mgr to the folder where the dll resides.
    Thanks for any help!
    -Jon
    Jon Accarrino replied 14 years, 5 months ago 2 Members · 3 Replies
  • Jon Accarrino
    March 22, 2012 at 10:47 pm
    bump
  • Edward Troxel
    March 23, 2012 at 3:41 pm
    1. Options – Customize Keyboard – click on “Global”, scroll down to File and find the Render As option and then assign a keypress.
    2. You don’t need to create the tracks first but… Select the audio files, right-click and drag to the timeline (or first audio track), and then choose “Across Tracks”
    3. If it’s a VST, I’m sure it would work. If it’s a DirectX, only if Cubase can understand DirectX plugins. So… probably no.
    Edward Troxel
    JETDV Scripts
  • Jon Accarrino
    March 26, 2012 at 7:19 pm
    Thanks so much for the reply.
    So, are Sony Vegas’ plugs DirectX?
