Activity Forums Maxon Cinema 4D Thrausi with Small Objects – Pieces are bouncing around on the floor?!
  • Thrausi with Small Objects – Pieces are bouncing around on the floor?!
    Posted by Jack Daniels on July 2, 2014 at 7:03 pm
    When I break a cube into many pieces and have a ball collide, the pieces fly off and then bounce on the floor, higher and higher (as if the floor was a really flexible trampoline!) I don’t know what’s causing this! I’ve set the bounce noise and the bounce on all colliders to 0% and that didn’t change anything. I cached it, and I’m currently changing mass to see how that affects it. If anyone knows the problem, can you guide me to the right direction? Thanks!
    Jack Daniels replied 12 years, 2 months ago 1 Member · 1 Reply
  • Jack Daniels
    July 2, 2014 at 10:17 pm
    Nevermind, I fixed the problem. I just lowered the steps per frame under project info.
