Activity Forums Adobe After Effects This style and sense of speed. Newb to 3d
  • Harryjf
    April 11, 2006 at 3:56 pm
    That sense of depth is created with a “Parallax”. Here’s a little more info on the concept:
    https://en.wikipedia.org/wiki/Parallax
  • Chris Smith
    April 11, 2006 at 6:58 pm
    This was done in 3D other than the band footage which was shot and match with the angle. Then the 3D camera flew around the world at it’s leisure as long as it didn’t give away the band were flat planes.
    Just create a large plane object. Populate it with flat cacti. You can do this pretty easily with particle systems. Then model the truck and have it move quickly across the plane. Make sure to use the fence and stripes in the road for they give away the motion. Also they set a procedural vibrate on the camera it looks like which also makes things seem way faster.
    Use a wide lens like the cam and things close will seem to truck along in the immediate FG. Then create a huge sphere and map your sky to it for the Distant BG so that it rotates correctly with the cam.
    Chris Smith
    https://www.sugarfilmproduction.com
  • Johnny_on
    April 11, 2006 at 10:35 pm
    Thanks for both of your replies…. Even less proficient with 3d apps so i guess i’ll have to give them a go 🙂
