Activity Forums Zaxwerks this is kind of weird-cant open file in ProAnimator but can in Invigorator
  • this is kind of weird-cant open file in ProAnimator but can in Invigorator
    Posted by Brandon on May 16, 2005 at 8:55 pm
    I traced a logo using paths then filled the paths in. Then I was using Invigorator in AE, then I decided to use ProAnimator for the same file, but it gives me an error saying there are no useable vector paths. Why is it that I can open it in Invigorator in AE, but I cant in ProAnimator? Isn’t that weird?
    Brandon
    Zax Dow replied 21 years, 1 month ago 3 Members · 2 Replies
  • Matt Rhodes
    May 17, 2005 at 12:57 am
    Hi Brandon.
    If you’re using Invigorator 4.x and ProAnimator 3.x, then there’s a chance we
    fixed a bug that made it into Invig 4.x — and will be available in ProAnimator 4.x
    when it is released.
    Matt Rhodes
    Zaxwerks, Inc.
  • Zax Dow
    May 17, 2005 at 5:52 pm
    ……. that bug was probably compatibility for Illustrator CS files.
    Until version 4 of ProAnimator is released, just save your file as an earlier version of Illustrator and it should open up fine.
    -Zax
