Activity › Forums › Adobe After Effects › This doesn’t make any sense…
  • This doesn’t make any sense…
    Posted by Corey Lynch on October 12, 2016 at 5:17 am
    I always render before I got to bed, so when I check my multiprocessing tab, it says that I’ll only be using 2(TWO) cores when I have previously been using 8. Why did it change? I didn’t change any system components or do anything in my BIOS it doesn’t make any sense as to why it would change. Can someone help me?
    Corey Lynch replied 9 years, 11 months ago 3 Members · 4 Replies
  • Tudor “ted” jelescu
    October 12, 2016 at 12:22 pm
    AE CC 2105 killed multiprocessing.
    https://forums.adobe.com/thread/1871469
    Tudor \”Ted\” Jelescu
    Senior VFX Artist
  • Corey Lynch
    October 12, 2016 at 12:24 pm
    Have 2014.
  • Walter Soyka
    October 12, 2016 at 4:23 pm
    Can you post a screenshot, please, so we can see what you see?
    The number of cores that will be used is highly dependent on RAM. Ae will not start a render instance unless it can get enough free RAM from the system to satisfy the minimum requirement you specify in Memory & Multiprocessing preferences.
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
  • Corey Lynch
    October 12, 2016 at 4:25 pm
    I found the issue. When you open up the multiprocessing tab while media encoder is open, it will change the number. Thanks.
