Activity Forums Apple Final Cut Pro Third party audio plug-ins
  • Third party audio plug-ins
    Posted by Oliver Peters on April 27, 2021 at 4:37 pm
    I’m finding that FCP is performing worse and worse with third-party audio plug-ins/effects/filters through each successive macOS change. I’ve moved several machines from Mojave to Catalina and now Big Sur. Under Big Sur, quite of few non-Apple audio plug-ins are slow to respond, cause application hang-ups (“application not responding”), or in the case of some Waves, the skeuomorphic UI is incorrectly drawn.
    These same plug-ins (under Big Sur on the same Macs) work just fine in Logic, Premiere, Audition, and Resolve. Some, like iZotope Ozone and RX, have an extra standalone app and that also works correctly in Big Sur.
    Probably no resolution until Apple decides to fix it in FCP. But any thoughts?
    Oliver Peters replied 5 years, 3 months ago 1 Member · 0 Replies
  • 0 Replies
