Activity Forums Maxon Cinema 4D Thinking Particle Textures…
  • Thinking Particle Textures…
    Posted by Kevin Snyder on July 31, 2006 at 6:35 am
    I would like to take an object and break it up into squares using thinking particles, but have the squares take on the texture from the original object. Right now, all I can to is apply one texture to all the new particles. I saw that someone said that the plugin “Storm Tracer” was required to do this in C4d… Is that true, or is there a way to do it without any plugins? Thank you.
    KMS
    Björn Marl replied 20 years, 1 month ago 2 Members · 3 Replies
  • Björn Marl
    July 31, 2006 at 7:00 am
    use the PFragment node on this. Make sure your object is all quad polygons and then set PFragment to Faces.
    Cheers
    Bj
  • Kevin Snyder
    July 31, 2006 at 3:44 pm
    Thank you for the fast response. Just a second thought, will the same node work for breaking my object up into spheres? Thank you.
    KMS
  • Björn Marl
    August 1, 2006 at 6:11 am
    You can replace the created geometry with your own shape, so yes.
    Cheers
    Bj
