Activity › Forums › VEGAS Pro › Thinking about moving to Vegas (from Premiere of course)
  • Thinking about moving to Vegas (from Premiere of course)
    Posted by Perry Cheng on January 26, 2006 at 4:25 am
    Just wondering if anyone has any input on this? What are the Pros and Cons on switching to Vegas?
    Sincerely,
    Perry
    Accountclosed replied 20 years, 8 months ago 8 Members · 13 Replies
  • 13 Replies
  • Gary Kleiner
    January 26, 2006 at 4:30 am
    Many folks have come to Vegas from Premiere.
    In once sense, you’d be better off if you had no experience with another NLE, because to have to unlearn some of the ways of thinking you use with Premiere/FCP/Liquid/etc.
    On the other hand, once it starts to click for you, you can see how many things are just so much quicker and easier in Vegas.
    I am curious about your own story about deciding to make the switch.
    Gary Kleiner
    Vegas Training and Tools.com
    Learn Vegas and DVD Architect
    http://www.VegasTrainingAndTools.com
  • Peter Wright
    January 26, 2006 at 6:01 am
    To add to Gary’s wise words, as a former Premiere user …
    Firstly, I don’t think it’s worthwhile simply comparing WHAT each program can do, because whilst there may be a desired feature one has over another, a far more important issue is HOW each program allows users to use its various functions.
    In my opinion, the ease and fluidity of Vegas is simply fantastic. As an example, you can drag the mouse to set up a playback loop on the timeline, and Vegas will continuously play back this loop uninterrupted whilst you apply almost any changes or effects, video or audio, track motion, pan/crop, colour correction, add new track and superimpose title, etc, etc, and you can see or hear the results of everything you do the moment you change any settings.
    In many other respects, the design of the Vegas workspace puts so many tools just there where you need them, rather than hiding them through a series of menus.
    There are many other great things, including:
    Takes (a wonderful feature for both video and audio),
    Velocity Envelopes
    Dragging Tracks up/down to change precedence and Unlimited Resizing of tracks
    Supersampling
    3D Track Motion
    multiple instances
    and … Scripting (another incredibly powerful feature)
    .. and lastly but not leastly, the various Vegas Forums – Vegas has an extremely responsive and helpful fraternity/sorority of users on this and several other forums.
    Peter Wright
    Perth, Western Oz
    http://www.allroundvision.com.au
  • Charley King
    January 26, 2006 at 7:36 pm
    Just to put my 2 cents worth in. I have Avid, Vegas, and Premiere Pro. I use Avid and Vegas for almost everything. I have hardly used my Premiere at all, to this point.
    Charlie
    ProductionKing Video Services
    Unmarked Door Productions
    Flamingo Las Vegas Hotel
    Las Vegas, Nevada
  • Charley King
    January 26, 2006 at 7:38 pm
    [Peter Wright] “As an example, you can drag the mouse to set up a playback loop on the timeline,”
    This is a nice feature, but I still have problems with it, for instance I do a split, then mark the tracks to delete the area ahead of the split, and invariably it sets a loop of one frame instead of deleting the tracks. That loop marking being so prevelant is always getting in my way.
    Charlie
    Las Vegas, Nevada
  • Charley King
    January 26, 2006 at 10:11 pm
    [Charlie King] “but I still have problems with it, for instance I do a split, then mark the tracks to delete the area ahead of the split, and invariably it sets a loop of one frame instead of deleting the tracks.”
    Never mind, operator error.
    Charlie
    Las Vegas, Nevada
  • Perry Cheng
    January 26, 2006 at 11:55 pm
    Thank you all… one more question, is the rendering really slow compare to Premiere Pro? Say render out to DVD MPEG2 format of 1hr video, how long will it take, say not many effect applied.
    Perry
  • Peter Wright
    January 27, 2006 at 12:34 am
    Apart from effects applied which you mentioned, rendering depends on processor speed.
    On my “ancient” machine (Dual AMD 2000) I would expect the sort of render you describe to take an hour or less.
  • Stephen Mann
    January 27, 2006 at 3:15 am
    I have two comments- First, I started with Premiere because “that’s what everyone uses”, but I got fed up with the workflow that went something like this: edit, crash, edit, crash.
    Vegas has never crashed my PC’s. In fact, I sometimes work for hours without remembering to back up the veg file. (Vegas is a non-destructive editor, meaning that the original media is never altered during editing, the veg file, which would fit on a floppy disc, contains all the editing instructions).
    Next, do you want your renders fast or good? I really hope that Sony doesn’t listen to the whiners complaining about the slow renders, because the quality of Vegas renders is unbeatable. Slow, but better than anything else in the price range.
    Did I mention that Vegas never crashes?
    And number 2.5: Vegas is software only – you aren’t stuck with any particular hardware or potential conflicts. If the PC can run Windows XT, it will run Vegas.
    Last, Sony Vegas has, without any doubt, the most common-sense, realistic and workable licensing terms of any other NLE softeware in the world. (This they inherited from Sonic Foundry, and I hope they never change it).
    And it doesn’t crash.
    Steve Mann
  • Ted Snow
    January 27, 2006 at 5:26 am
    Ditto Steve…using Vegas for almost 3 years and not a single crash. Rock solid stable. I just rendered out a 1hr 9min video of old 8mm film which I had to do some color correction etc. and it took about 2 hours on a p4 2.8 ghz machine. Vegas was my first (and last) NLE. I wouldn’t think of switching to anything else. It does everything and more than I will ever need.
  • Bruce Bernard
    January 27, 2006 at 1:29 pm
    I too was facing the decision whether to upgrade to Premiere Pro or switch to Vegas. I am a hobbyist, albeit it a rather serious one, so a lot of the advanced features of both programs are not of that great an interest to me.
    So I downloaded the trial versions of both programs. For me, I had to balance the time to learn a new program (Vegas) versus its features and benefits. The choice turned out to be quite simple.
    Premiere Pro (1.5 anyway, I can’t speak for 2.0)is the same kludgy program as the earlier versions of Premiere, just dressed up a bit. Vegas on the other hand is very intuitive, and displays most of the everyday stuff in real time without any special hardware. To get Premiere to work reasonably well you need a special board like the Matrox RTX100.
    One important point is the term “render”, which is actually used in 2 contexts. In Premiere, you need to render preview files, even a simple dissolve. Dissolves render very quickly, but each time you make a change you have to re-render. (Right click, select ‘Render Work Area’) This is one command that you will quickly memorize in Premiere. If you import anything other than a file that matches your project specs, you will need to render. For example, if you have a background that is a .mov file and you import it into an .avi project, you need to render just to see your previews. Very time consuming even for a hobbyist guy.
    In Vegas, “render” means outputting your project in its finished form, such as MPEG2. This type of rendering time is of no concern to me either in Premiere or Vegas becasue that’s the last step before I go to bed. That’s what we have comnputers for – to work while we sleep. But Vegas’ ability to apply filters, transitions, effects, etc. on the fly and view the changes in real time, even on a modest processor, is outstanding. I used the trial version on an AMD 1.3 chip and the results were phenomenal. I’m upgrading to an AMD dual core 4800 chip so I expect I will have even better response. For complex effects, you may need to do RAM previews or selective pre-renders, but for what I do, so far I haven’t seen the need.
    The only drawback to Vegas was that it does not have the support for Smartsound (Quicktracks)like Premiere does, probably because it competes with its own Acid product. I really like Smartsound and have purchased a lot of the music. But there are several workarounds. For me, I still have Premiere so I can output my Vegas Project to .avi and then add the music in Premiere. I also have Sonicfire Pro 3 which can be used to create the music tracks. I am also experimenting with getting SFP3 to open as my default sound editor in Vegas. So far I haven’t been able to get that to work but I think I will be able to. If anyone has done that successfully please let me know.
    So bottom line: Learning Vegas is well worth the effort, and if I was starting today, Vegas would be an even easier choice. Good luck.
    mrbb, PA
