Activity › Forums › Creative Community Conversations › Things that are broken in Mountain Lion
  • Shane Ross
    July 29, 2012 at 10:53 pm
    Livetype was discontinued before LION…integrated into Motion. So yeah, they aren’t keeping that app in mind when they make new OS’s
    AGAIN…if you have a good, working system, why update? I only update when I am forced to. I mean, I just got LION up and running for Avid MC6…in May.
    Shane
    Little Frog Post
  • Steve Connor
    July 29, 2012 at 11:06 pm
    I always clone my system drive and update that, then give it a few weeks to see if all is well.
    So far so good with ML
    Steve Connor
    “The ripple command is just a workaround for not having a magnetic timelinel”
    Adrenalin Television
  • Bret Williams
    July 30, 2012 at 12:53 am
    It wasnt integrated into Motion. When Motion came out, it included the libraries from LiveType. But you can’t open a LiveType project with Motion, and there are features in LiveType, like extruded fonts that aren’t in Motion.
  • Paul Jay
    July 30, 2012 at 7:54 am
    Anyone that upgrades a perfect working system to a first version of a new os is always asking for troubles.
  • Rick Lang
    July 30, 2012 at 12:03 pm
    I agree LiveType 2.1 refuses to load on my iMac, but I checked Soundtrack 1.5 and it loaded! I posted a note on Apple Discussions in the Mountain Lion group to see if anyone has any insight into a solution:
    https://discussions.apple.com/thread/4157174
    Rick Lang
    iMac 27” 2.8GHz i7 16GB
  • Oliver Peters
    July 30, 2012 at 12:19 pm
    I don’t remember the specifics, but somewhere I read that ML gets rid of some more of the 32-bit legacy library files. LT probably needed these.
    Oliver
    Orlando, FL
    http://www.oliverpeters.com
  • Rick Lang
    July 30, 2012 at 12:49 pm
    I suspect this was a result of the new ProKit 7.3 in Mountain Lion even though it didn’t break Soundtrack 1.5. Final Cut Express HD 3.5 still works too by the way. I don’t use these any longer but always nice to have them working in case I wanted to revisit old material.
    Rick Lang
  • Chuck Pelini
    July 30, 2012 at 2:54 pm
    I upgraded to Mountain Lion and have no problems opening LiveType. I just revised a spot in which I used LiveType’s glow effects on text and it opened fine.
  • Rick Lang
    July 31, 2012 at 4:25 am
    Chuck Pelini:
    “I upgraded to Mountain Lion and have no problems opening LiveType.”
    Very interesting. What machine is running you Mountain Lion?
    Rick Lang
  • Rick Lang
    July 31, 2012 at 6:24 pm
    Since I knew it worked for you, I tried to open it again today but did not elect to reopen the (unopened) window that was saved when I force quit it yesterday. Surprisingly, it came up fine with new windows today. So it must have been a glitch that has affected me and some other people on the first attempt at opening the application but after a shutdown I suppose it corrected itself.
    Rick Lang
